Opening pool by myself, since I am forced to stay at home for 5 more weeks. Where does this go?
mchopra
12
Cincinnati, Ohio
I decided to take the pool opening on by myself. I took off the cover, am filling the pool with water, and removed the plugs in the skimmer basket foundations, and the outlet plugs for water outflow. I was able to find assorted plugs inside my Pentair variable speed pump filter basket, I sealed all of the openings that I could see. Here is my issue- I found this black plug with old Teflon tape on it, where does it go?
Thanks and stay safe.
Manny
PoolGate
4,490
Damascus, MD
The pump usually has 2 plugs.
Also FYI those plugs are better off with a silicone lubed oring than Teflon tape. If you can get out to the hardware store, bring the plugs and match them up with an oring!
setsailsoon
2,544
Stuart/FL
Manny,
Please do fill in your signature at the link Marty provided above. Your plug issue is a perfect example of how the signature gets you better advice quicker by avoiding a lot of repetitive questions on their part. Also a photo of the equipment pad and your pool would be helpful.
Hope you get everything up and running quickly!
Chris
mchopra
12
Cincinnati, Ohio
We need details of your pool equipment.
Hi,
‘’I have an free form pool, 35,000 gallons gunnite. I have a Pentair Intelliflo 3 HP variable speed pump, Hayward sand filter, Hayward variflo valve, Caretaker 5port cleaning system, Raypak heater, Jacuzzi salt water cell system.
I am trying to post photos next.
Thanks
Manny
mknauss
26,550
Laughlin, NV
I put the pool details into your Signature.
Check the heater. That looks like a heater drain plug. It should have an oring, not teflon tape.
mchopra
12
Cincinnati, Ohio
Manny,
Chris
Thanks for your assistance.
Hi,
I placed 2 white/opaque ones into the side bottoms of the Pentair pump. I just don’t know where this black one goes.
Newdude
2,426
NY
They look like the plugs for my Pentair VS pump. Mine takes 2. One for the basket area and one for the motor/impeller area
PoolGate
4,490
Damascus, MD
Hi,
Saltwater generator? Mine has 2 plugs in the pump, 1 in the heater (hard to find) and one in the saltwater generator housing. It goes somewhere! Once you start up your pump, you'll find it I suspect. If not, turn off the pump until you do!
