Opening 12x24 intex ultra frame salt water sand filter pool
Bwilsonmom5
Active member
Mar 21, 2022
25
Ripon, WI
This was our first winter for this pool and have a few questions on it. We live in central wisconsin, lots of snow. I did drain the pool below valves, put my pump and everything in the house for winter, I did not cover it. Still some ice on it of course but my level looks above the valves right now.
only 2 feet lowered (water) how much salt should I add to reopen when it thaws. Anyone in Wisconsin with any advice on the whole re-opening would be great, at what temp outside? how much salt? will I need new sand? Only one summer last summer so I think the sand should be good. Any ther chemicals I should add. Looks pretty clear but again still a little ice on it and cant tell much
Get a salt test kit and determine your currents alt level after you get the pump running and circulate the water for 24 hours.
Calculate the salt needing using PoolMath
Best to open it before your water temperature gets above 60F.
No. Sand lasts for man many years.
