Hello. New pool owner & forum member here and apologies in advance if this is a silly question. We are expecting freezing temperatures and freezing rain here tonight in Atlanta so I was trying to get out ahead of it by doing some research. I read that for proper freeze protection the spa drains should be slightly open to allow complete water circulation, and my spa drains were closed.
I tested opening the spa drains today -- and everything seemed fine... I was still getting adequate water flow over my spa spill into the pool... but when I shut off my pump I noticed 20 minutes later that the water level in my spa was lowering... and 45 minutes later that the water kept lowering - 6" below normal. I turned the pump back on and the spa filled back up. Any ideas what could be happening? I have an overflow drain in my pool which may be worth noting here if the water is draining to the pool. Thanks in advance.
