So - the pool is going into its 8th month of water in it. I had a issue in August - where of course, we went on vacation....pump stopped running for some reason.....and ALGAE. I did a SLAM when we got back and all was good for a couple of months. I guess between monsoon rains and water fills, I let my CYA down a bit (30) and boom! ALGAE! Did another SLAM....passed the overnight test - crystal clear water - but high level of chlorine. I brought my CYA up to about 70 -80 (I have SWG). And it took forever for the chlorine to come down from the SLAM level (about 30). I am talking at least a month! When I got to around 7 on the chlorine - BOOM!!!!!! Algae!!!!! I can't figure this out. Now I am at a 80 CYA and currently SLAMMING AGAIN.
The algae is a very subtle, green algae. I can barely see it until i brush it. And then it dissipates into a cloud.....I dont see a lot of algae on the walls, skimmers, or waterline. I definetely notice it first on the sun shelf and steps...
Current levels:
FC - 32
CC - 0
Ph - 7.6
TA - 90
CH - 260
CYA - 80ish
Temp 76
I just cleaned the filter yesterday (it was green, but not terrible) - and I brushed floor, walls, EVERYWHERE - I also have my robot doing double time on the floor and walls to keep things stirred up.
I live in South Florida and the pool gets sun from 10 AM to 5 PM (winter) and 7 PM (summer) - Pool temp can creap up to the 90 degree mark in summer. I have Pebble Tec Brilliance "Clearwater" which is a little on the darker side as far as finishes go. It is also a bit more "Porous" than most finishes. By that I mean it has a lot more "nooks and Crannies" in the finish (due to glass beads, round aggregate, etc). Could this be an issue with the algae having more places to "hide"??? I am at a loss here - Hoping for input.
Current levels:
FC - 32
CC - 0
Ph - 7.6
TA - 90
CH - 260
CYA - 80ish
Temp 76
