- Jul 21, 2013
- 52,502
- Plaster
- Pentair Intellichlor IC-60
Follow the SLAM Process step by step with no shortcuts.
Third bullet point says:
Sixth bullet point says:
- It is best to use bleach or liquid chlorine when SLAMing. You will want to have enough on hand to raise the FC level to shock level at least a couple of times. It is especially important to avoid using dichlor when SLAMing, as it will raise CYA far too quickly.
- Check and adjust the PH to between 7.2 and 7.5. The PH test isn’t reliable during SLAMing so make sure to take care of this before you start.
