I guess when i was weed eating, i broke off the on and off button, and now the pump is off..Anyway to turn back on manual until i get fixed. I dont want to get into water issues, since i cant circulate water at the moment..
Pool Motor end cover with 2 speed pump switch Fits 56 Frame - 5-5/8" body Motor MAGNETEK / A.O. SMITH 1-83333-01 THIS IS A TWO-SPEED TOGGLE SWITCH KIT USED ON THE MAGNETEK LASER SERIES THRU BOLT MOTORS THIS IS A PLASTIC END COVER WITH
www.cshincorporated.com
The cover looks to be pretty much universal in design from the other manufacturers. I assume the switch is just a standard Lo-Off-Hi which means you should be able to go to any electrical supply store with the broken switch and have them match it up. Or I found Hayward has a 2 speed switch; Hayward ECX13252
After looking at my blow up pic, I was able to get needle nose pliers, and grasp the little section of the switch I didn't notice, and flip the pump on...At least I now have it running until I get a new switch...Thanks for all the help..
I had the same issue years ago. If you don't switch from Hi to Low often, then maybe just have the pump on a timer and turn it on/off with the timer. Maybe you already have a timer on it and can control it that way.
