mdittmer
1
Sarasota, fl
Hello!
New pool owner here! I just upgraded my pool equipment from an Aqualogic to an OmniPL. I'm sure I've misconfigured a sensor somehow but I can't figure out which one? My pool and spa share the same pump (brand new Hayward maxflo 500 VS) a when my pool is on the temp is accurate (currently 86 degrees F), but when I switch to spa mode it says 116 degrees and will shut itself off every minute or so if I try to use the heater. I can run the spa jets without the heater just fine, and the pool heats fine as well. Any idea what might be misprogrammed?
Thanks!
Welcome to the forum.
The automation uses the same sensor probe for both pool and spa temperature. Are you sure it is not the spa temperature setting in the heater that is too low?
