Hello!
New pool owner here! I just upgraded my pool equipment from an Aqualogic to an OmniPL. I'm sure I've misconfigured a sensor somehow but I can't figure out which one? My pool and spa share the same pump (brand new Hayward maxflo 500 VS) a when my pool is on the temp is accurate (currently 86 degrees F), but when I switch to spa mode it says 116 degrees and will shut itself off every minute or so if I try to use the heater. I can run the spa jets without the heater just fine, and the pool heats fine as well. Any idea what might be misprogrammed?
Thanks!
Thanks!
