It's not the same. It is NEW dead algae that you have killed (but more live algae remains) with chlorine.
Each day, you kill SOME of the algae but not all of it. You vacuum up the dead stuff (I would stop vacuuming to waste....go to filter) The next day, you repeat the never-ending cycle of dead algae back on your pool floor so you kill some BUT NOT ALL of it.
Go back to basics and SLAM your pool. The SLAM article must be followed to the letter or you will never get out of the circle you are in.
Well, as annoying as that is, it's comforting as well to believe I'm at least on the right track! It has been 7 days starting today that I've been meticulously following this process. My cya tube I have felt confident has been at 60 or just under, but I think I'm going to adjust up to 70 and keep it at 28. If this truly is new algae then I should probably be vacuuming 3-4 times a day as I see it coming back that often through the day. Thank you all.
