FC: 15.5
CC: .5
CYA: 40
Ph: 8.0
TA: not recently measured
I’ve been in SLAM mode for four days (Keeping FC 16-17ppm).
The reason: The pool hadn’t been swam in for a week. Yellow/brown sediment on the bottom, but not the sides. I believe it was pollen (based on forum posts I read here). I scrubbed and SLAMMed and it was crystal within a day.
But, I’m still losing 2ppm in OCLT (Been doing OCLT since day one of SLAM). So two newbie questions:
Air temp is 46 low, 59 high - getting a freakish cold spell. Water temp is 85
Will the evaporation cause chlorine loss? Could that be the culprit? For example, after sundown my FC was 15.5. I added 50oz of 12.5%, and three hours later the FC was still 15.5.
2) Would frogs hanging out in the skimmer overnight cause that kind of loss?
I understand chlorine is consumed by sunlight and organics. I feel like an idiot even writing this question, but do frogs count as organics?
I’m at a loss as to why I’m still failing OCLT after four days - that’s never happened before. The only new variable here is air temp.
Thanks much!
CC: .5
CYA: 40
Ph: 8.0
Thanks much!
