The Oasis Platinum heat pump claims to be efficient to 40*. Does anyone have one of these heat pumps? Is this just marketing BS? I've requested more info but would love to hear from an owner.
While a heat pump may "work" if the air is x degrees cold it is still only going to heat it a couple of degrees over the water temp which could be colder than x to start with So I'm leery of how much help it will be in 40 degree weather.
Maddie![]()
Heat pumps have their place but not in colder climates. You need temps in the 70's for it to produce at a good pace. In the shoulder seasons, early spring and fall when temperatures are low it'll work but very slow. In your climate the best way is NG heaters. Sized right can produce 1-2 degrees an hour.2
As the outside air gets colder the heat pump BTU output drop
So my oil furnace is in a utility room about 10 ft from the heat pump. The furnace room is typically rather warm in the high 80s/low 90s. If I moved it inside, how much better would it keep up with cold water ? Would it be enough to overpower it or still struggle ? If it could handle the warmup I would definitely use it like a gas heater to warm up on short notice for a weekend party.
Yea, that I understand, but is there a chart that each company has that shows the BTU at specific temperatures? Could the Oasis actually produce more BTUs at lower temps or is that pretty much the same across all brands since there is only so much heat in the air to extract? It seems like most are rated to the produce their listed BTUs down to 50? Our march/april and oct/nov is going to be in the mid 40s often so if this one could eek out a few more BTUs at slightly lower temps it'd be a big help.
People on this forum seem to like the Raypak calculator and it says it could heat our pool to our desired temp April-Oct and save us a few hundred over nat gas. Is their calculator pretty accurate?
You would not believe how much heat a pool takes, or how little there is in air! It would make that utility room arctic in 10 minutes.
You need to post the specs on your pool in order to have a meaningful discussion about using a heat pump for your pool. Do not confuse efficiency with ability to heat a medium to a specific temperature ( heat output). Heat Pumps are very efficient at all temperatures but quickly lose heat output as the temperature of the medium you are extracting heat from drops. You are also somewhat limited by the size of the heat pumps available for a pool. You must also realize that in order for a heat pump to work that the pool circulation pump must be running thereby decreasing the efficiency of the heat pump by adding the cost of the electrical energy of the circulating pump to the cost of the heat produced. We would also need to know the goals you are trying to achieve i.e. pool water temperature preference when you are swimming. Whether or not you are using a pool cover. Is the pool indoor or outdoor? What is the surface area of the pool? What is the total water volume of your pool? It is difficult to give a quantitative answer without knowing the specifications and variables.
