Oak leaves clogging Warrior SE
dianedebuda
454
Austin TX
It's that time of year when the Live Oaks drop their leaves. I don't have all that many on the bottom, but seems like they get stuck in the center, bottom flexible mesh quickly and clog up the intake within just a few minutes. Is there a work-around for the robot (other than cleaning it every 5 minutes or manually scooping/vacuuming)?
mknauss
37,059
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Try removing the fabric seal at the bottom of the basket. You will lose some debris when you remove the robot for cleaning.
dianedebuda
454
Austin TX
Removing the fabric seal worked like a champ. Probably will be able to put it back in next week when the oaks have finished shedding their stiff, sharp pointed leaves.
(y)
Reactions: mknauss
