You can swim as soon as it's filled without issue.
Thank you
So with a MiniPebble finish, how long does one have to wait to swim? I have read so many different time frames that people are saying. What are the recommend times or what have you done... I will have about 2 weeks once the finish is done before my 50th birthday pool party that the wife has planned. It's a surprise party that I'm not supposed to know about. So I'm asking about using the pool so I can get that info to her so in case she has to move the dates....
The same bond wire that goes to the pumps and heater would connect to the water bond
You can see it here (bottom of the third pipe from the right):
So I’m kinda lost as well, I’m not sure I have this and not sure if it’s needed and what purpose does it serve. Care to shed some light on this for a pool noob
The purpose of bonding is to get all surfaces and materials in and around the pool at the same electrical potential. If there are differences then that's when people can get shocked or feel a tIngling sensation.
Depending on your setup the water can very well get bonded by the heater, some pumps or the pool light niches but since every pool is different, Building department's use water bonds as a catch-all since they really can't be sure if the water actually gets bonded.
I personally don't feel that a dedicated water bond is necessary in most cases but it's an inexpensive item that has no real downside to installing anyway... and if required by code, the decision is made for you
B- you might want to do a little local digging...
Steel Ladders & steel niches can satisfy water bond under most adaptations.
Heaters, stainless filters etc are not satisfactory water bonding -
they were ruled out, with the logic if a system looses prime they would not perform the task.
Water bonding has to below the normal operating water level of the vessel.
This ruling came our way about a year ago, for some reason we copy every California does about a year later.
Perma-Cast PB-2008 Water Bonding Fitting, 1" NPT Bronze
It's just a clamp that pinches the wire. Is that what you're talking about?
