Hey Everyone, I apologize for what will come across as a very novice question but I’m looking for some advice. I am building a 38 x 16 fiberglass saltwater pool with a separate tanning ledge that has a bubbler. Planning on a couple waterfalls from the elevated tanning ledge into the pool as well as two Pentair laminars. Additionally we use mostly Control4 for our A/V stuff and are not opposed to having separate automation for the pool if it is easier.
My main question is with regards to the automation options. My builder is quite experienced but I suspect does not get very involved in the techy aspects of pools. He quoted me and easytouch and seems a bit confused when I ask him about Intellicenter, Intellitouch, etc. in the forums I myself having a hard time trying to pin down exactly what people are referring to when they discuss the various automation platforms. Is EasyTouch the same thing as Intellitouch or Intellicenter? Is screen logic an add-on to EasyTouch or Intellitouch or Intellicenter? These kinds of questions. I feel inclined to get the most up-to-date advanced technology I can within reason pricewise but he seems to give a bit of pushback With respect to whether or not I need anything beyond the standard easytouch with the Wi-Fi upgrade which he quoted me at $500. Don’t want to have a lack of options down the road if I were to add a separate water feature, waterslide, anything else. If anyone could fill me in on some details as far as the capability of the systems that would be greatly appreciated as I’m not sure my pool builder can exactly do that. I did discuss upgrading the system to the IC40 instead of the IC20 which is what he bid me. I have no doubt that the system he bid me would work just fine but I don’t want to be limited in the future. Thank you for your time. Also the complicating factor is obviously availability right now since he has the easy touch panel and I would assume would have to track down and then Intellicenter.
Thanks
Thanks
