Not understanding App recommendation
Welcome to the forum!
You have input that you will set your SWCG at 6% output. That is not possible with a Krystal Clear SWCG I believe. Where you have 6, put 100.
The FC targets are so low because you must have 0 CYA input into the app. You need to add CYA if you have not already.
Recommended Levels
I suggest you read ABC's of Pool Water Chemistry.
