carlp
Does your spa have a drain at the bottom? It will only pull water through when you go to Spa mode on the Easytouch. Your automatic valves will divert away from the pool skimmer and pool returns, to spa drain and jets. If you set the filter to "Filter" and run it in Spa mode, maybe you can brush the dirt into the drain.
On the IntelliChlor menu, there is a separate SWG percentage for Spa Mode, which you'll also want to set to 0% if you are still doing OFCLT.
