Thanks for the feedback Nursenini...The drawings are being amended and all should be good including light placement. When I found this site I read thru several pool builds including yours. Lots of good info and I must say we are still nervous about owning a pool. The girls will be so happy for sure. Questions...
How often do you use your pool heater? Would you get one if doing over?
I'm considering aura bright on my pool finish...any thoughts on it?
I decided to go with a 2 speed pump instead of VS but not having a spa I should be fine...
Do you have automation for your pool that can be used on cell phone?
Any concerns with exposed aggregate for decking? I get mixed reviews from my reading
Thanks so much for taking the time and many Blessings back at ya...
I'm still nervous about having a pool, too! Lol!!
Heater- yes, I'm glad we have it and would do it again. We have used it several times, including for my birthday the end of October. It was hot outside but the water was cold. Heated it up and enjoyed swimming for my birthday! I have also used it to nudge the water up 8-10 degrees so we could swim comfortably when the water wasn't quite warm enough. Of course, we use it for the spa as well. I had not wanted a spa, but hubby did. I'm glad we have it now as the grandkids LOVE it! They call it "the little pool". This winter when we had warm temps, I heated the spa for them to swim in since it was not feasible to heat the pool from 50 degrees.
I dont know anything about aqua bright right but I'm sure others can give you their opinions.
I have a VSP, which was what we wanted instead of the 1 speed pump my builder was going to give me. I don't know enough to recommend a VSP vs a 2 speed. Again, others could probably steer you better on this subject.
We have all Hayward equiptment and automation. We have the Omnilogic system. We were supposed to get the Prologic but switched to Omnilogic specifically for the ability to control it with our phones. I still don't KNOW the system really well but love the functionality of it.
Personally, I'm not a fan of exposed aggregate. From an esthetic standpoint, it's not my thing. I'm more drawn to stamped concrete or travertine (my fav), or pavers. My understanding is that exposed aggregate gets really hot. Our stamped deck gets pretty warm so we end up spraying it down for the kiddos (and my hubby). Travertine is supposed to be much cooler.
If we ever tear out our deck, I will replace it with travertine.
Hope this helps!
