Normal Repair Cost for Heat Sensor Replacement
Sharkygirl
118
Key West, FL
Hi, I was wondering what is reasonable for time spent to replace a jandy heat sensor. My pool guy charged me for 4 hours of his time to replace the sensor. I looked up how to do this on youtube and it seems rather easy. He is charging me $125 and hour, that's $500!! WHAT! No Way. How can this be?
Jimrahbe
15,382
Bedford, TX
Sg,
If all he had to do was replace the part then that is outrageous.. If the problem was odd and he had to troubleshoot the problem to find that it was the temp sensor, then it does seem high but not that bad..
I used to run shops repairing non-pool products.. We would often spend a couple of days to just to find a bad resister or bad solder joint.. Parts cost five cents, but the labor to find the problem is what our customers were really paying for.
JamesW
17,003
What exact part was replaced?
How much time was spent on diagnostics vs. actual replacement of the part?
Ask for an explanation of why it cost what it did.
AUSpool
728
Brisbane, Australia.
$125 sounds excessive as an hourly rate. I guess Jandy parts are bit pricey? I replaced a name brand temp sensor, the new sensor cost me ~$70, and it took me about 30 minutes. Even if Your new Jandy sensor was $100, $100 an hour still sounds excessive. He must have supplied and installed a bunch of new plumbing.
sktn77a
1,453
Chapel Hill, NC
Meh, $100+/- an hour is probably the going rate depending on where you live. But 4 hours is excessive for a professional to do this work. Get a firm estimate in future, before any work is done, and consider finding a new "pool guy".
