Being a new pool owner, I am not sure what to do.
It started raining non stop this morning in MD to the point my pool water is an inch away from the coping and over the top of the skimmer. This morning before the rain started, the water was only covering a 1/4 of the skimmer. The rains are suppose to continue for the next several days.
Should I be draining water from the pool to keep it from overflowing? Are there dangers in having the water overflow? If I should drain some of the water, where should I drain it down to?
My pool is a Fiberglass Pool, if that makes a difference.
Should I leave the pump running with the water being so high?
Should I increase my SWG? Or should I being adding bleach during all of this rain?
Suggestions are greatly appreciated.
Thank you
caroline
Thank you
caroline
