Hi there,
We just purchased a new home and the pool filter has no option for “waste”. I need to vacuum on the waste setting, is there another option I can use?
We have: Filter, Rinse, Whirlpool, Backwash, Winterize, and Drain.
Should I be vacuuming on Rinse?
(Not sure if it will help but, it’s an above ground pool... 39,400 L .. 21 feet .. sand filter.
We have done everything we can to clear the water, the levels are all good according to the water analysis I did today: alkalinity 104ppm, calcium hardness 302 ppm, pH 7.4, Stab 46 ppm .. chlorine is high because we just shocked it 48 hrs ago free chlorine was at 10.02 when we tested this morning.
Anyways, nothing is getting our water clear, we were given the Floc “magic potion” to try. It says to let it settle for 12 hours with pump turned off and then vacuum to waste, but we don’t have the waste setting on our filter. Any advice will be appreciated!)
