- Jun 24, 2021
- 8,759
- Vinyl
- CircuPool RJ-60
This cell is rated to produce 384g/day or .84lb/day. Which is about right...if it produces that.It has 5 leds and then "boost".
I ended up at LED 2 and had been running 8 hours a day for a while at that point.
This is a "20,000" gallon generator and I have an 11,000 gallon pool. Obviously I take that 20k with a grain of salt, which is why I got the 2X of my pool size vs 50% bigger.
IF I remember correctly, I jumped on the SWCG install when I did (had it in the closet for a min) because my chlorine levels were gone (or fading fast). Put it on boost, but was running 24/7 then, and it climbed and climbed. At some point I backed off to 8 hours and was still climbing so I cut back... then cut back more, then more.
It IS possible I have my brain all mixed up and the 8 hours did happen in that sequence and maybe that is what is screwing me up. I just don't FEEL like that happened. But I'm not gonna deny that I could be mistaken.
The 5 leds and boost, means that each increment is about .15lb/day Each LED means, in your pool, running 24 hours per day is adding 1.6ppm.
LED 2 would be 32% output, and with a runtime of 8 hours, would be 1ppm of FC. In Louisiana in Spring, I would guess your FC demand to be about 1-2FC...which seems reasonable.
So, I'm going to suggest, you have a testing problem. One of the precepts of TFP is good testing. Without it, we are shooting in the dark.
I know $$ might be tight, but you will spend more chasing your tail with chemicals and effort than getting a good test kit.
I recommend you buy a good test kit. Link-->Test Kits Compared
When it arrives, post a full set of results.
Without a good test, we might make recommendations that will do more harm than good.
