Is it true that the presence of nitrate in pool water at a concentration of 20 PPM or greater will drastically increase your sanitizer consumption? Thank you.
No. There is no direct interaction between nitrates and chlorine. My nitrate levels are above 80ppm and I have very minimal FC loss even in the hot summer months.
Nitrates do act as an algae nutrient, like phosphates. However, in a clear, clean, and properly managed swimming pool, the nutrient levels won’t have much impact. It’s only in pools where the FC levels are allowed to drop or go to zero that high nutrient content pool will develop a fast algae bloom.
Follow TFP recommended levels and you can ignore nitrates and phosphates if you want.
No. There is no direct interaction between nitrates and chlorine. However, in a clear, clean, and properly managed swimming pool, the nutrient levels won’t have much impact. Follow TFP recommended levels and you can ignore nitrates and phosphates if you want.
