- Feb 6, 2015
- 7,809
- Plaster
- CircuPool RJ-45 Plus
There it is, thanks Marty!I moved it to your Signature block.
Ok so interesting.Profile and signature are two different things. Click the link I posted.
I really can't see much detail in your profile - that is why the signature is important.
Your filter may be just fine for day to day use if you don't mind cleaning it frequently.
The larger the filter the less you need to clean it. I hafe a 12300 gallon pool and a 420 sq ft cartridge filter. I clean it whenever the filter pressure rises 25% avove clean pressure (pump at 3000+ rpm). It's nefer fone up 25%, but I still clean it yearly.
As you have found out, your filter clogs up quickly when trying to vacuum during a SLAM.
Yes! It really is - just hard to tell with the angle and the sun..I hate to read anything into your pictures as angle, lighting, camera quality, etc all play a factor. But are you sure it's crystal clear water?
Examples: How Clear is TFP Clear?
Of course now I am experiencing some doubt now that I saw those other pictures. I think I can still get it a bit more clear relative to those pics.I hate to read anything into your pictures as angle, lighting, camera quality, etc all play a factor. But are you sure it's crystal clear water?
Toss a quarter in the deep end.Of course now I am experiencing some doubt now that I saw those other pictures. I think I can still get it a bit more clear relative to those pics.
How's your cartridge filter pressure? How is flow out of pool returns? One issue typical for sand filters is that you can kill all the algae, but they're slow to filter out the dead cells. It might be the case that your cartridge filter is full of dead algae and needs to be cleaned, and more time given to get the dead organics out of the pool water.Of course now I am experiencing some doubt now that I saw those other pictures. I think I can still get it a bit more clear relative to those pics.
