This is from the FAS-DPD test, correct? (not the yellow/orange OTO)Latest results:
FC: 6.5 (looks very high, maybe because I've been running the pump for a long time while adding stuff and rot reducing the % the SWG is running (60%)?)
If the SWCG starts operating, the PH will climb with the higher TA. I would focus on slowly lowering your TA via Muriatic Acid doses that lower your PH (aim for 7.4 to not overshoot, low PH is bad for vinyl). You can speed up the process if you can create aerationCC: .5
CYA: 30 (added 2lbs of CYA and will add another 1lb)
PH: 8.2 (not sure why this shot up, will add 1 qt of Muratic Acid 31.45% 20% Baune)
TA: 140
CH: 300
Salt: 3,300 (added 160 lbs of salt)
Any suggestions?
Yes it gets "boring" eventually!Thanks for taking the time to reply. The FC is from the TF100 test kit. Hopefully once I get things where they belong this will be easier to control.
