Newbie Looking for Advice
SteveK52
72
Taylors South Carolina
Latest results:
FC: 6.5 (looks very high, maybe because I've been running the pump for a long time while adding stuff and rot reducing the % the SWG is running (60%)?)
CC: .5
CYA: 30 (added 2lbs of CYA and will add another 1lb)
PH: 8.2 (not sure why this shot up, will add 1 qt of Muratic Acid 31.45% 20% Baune)
TA: 140
CH: 300
Salt: 3,300 (added 160 lbs of salt)
Any suggestions?
Reactions: splashpad
splashpad
1,994
SE Kansas!
Latest results:
This is from the FAS-DPD test, correct? (not the yellow/orange OTO)
CC: .5
TA: 140
CH: 300
Any suggestions?
If the SWCG starts operating, the PH will climb with the higher TA. I would focus on slowly lowering your TA via Muriatic Acid doses that lower your PH (aim for 7.4 to not overshoot, low PH is bad for vinyl). You can speed up the process if you can create aeration :)
Your calcium is at the top for vinyl pools, I would make sure to not add any forms of CAL- to your pool water.
SteveK52
72
Latest test data
FC: 5
CC: 0
CYA: 50
PH: 7.6
TA: 140
CH: 300
Salt: 3300 (taken from pentair software (does anyone know how accurate this is?))
I'm planning on bringing the PH closer to 7.4 and raising the CYA closer to 70.
Any Suggestions?
mknauss
23,544
Laughlin, NV
You can add a bit of CYA over the next month if you like. But do not mess with the pH until it gets to 8. Then lower it to 7.6. That rise will be fairly quick until your TA comes down some.
The IC40 Salinity reading is fine. But, in your area, I would suggest getting the Taylor K1766 salinity test at some point. You get rain, and thus your pool may overflow and you will need to add salt. It is never good to rely on the SWCG reading for how much salt to add.
