Hello,
New pool owner here and I have my first issue. My water was cloudy yesterday morning - I tested the water and there was just about zero Total Chlorine. I recently purchased a TF 100 test kit. Pool is an above ground, 8,800 gallon pool with a Hayward automatic chlorinator. I checked the chlorinator and found that it was empty. I shocked the pool and refilled the chlorinator and dialed it just about to max. The water is slightly clearer today, but still a bit cloudy and the Total Chlorine is still measuring below the lowest level on the tester.
Should I shock again, stay the course and let the total chlorine level come up on it's own, or go a different route? Also, should I test and/ or post any other values? As I mentioned, I new to the TF 100 and not really sure what tests to perform.
TIA
TIA
