Hey guys, this is my first year opening my pool from winter hibernation. It's a small little guy, 4600 gallon above ground. I brought it from cloudy green to sparkly blue (which I'm actually quite pleased with myself about), and am super close to having my levels dialed in, but I'm at a point that I'm a little hesitant on what to do next, and how to manage my particular situation long term.
Current levels
Fc (yesterday was 5, didn't test today)
Cya 45
Ta 120
Ph 7.5
Hardness 70
Well water (my fill water) 200 ta ?
No idea on temperature, probably 60-65 ish? I had no idea this even mattered until reading through some posts on here!
Last Sunday my cya was 60, I shocked to 24 (ish, didn't actually test it, just went off pool math calc using bleach) , then drained another 1/3 of the pool (long story, dont ask) bringing my cya to 45. I didn't add anymore chlorine, so my fc has been really holding pretty dang good (I think?).
I started with ta of 170, and brought it down over 2 days with about 1/3 of a gallon of 31% ma, and brought my ph back up by aerating (last ta and ph tests were 24hrs after last time I added ma).
So my questions are 1) what should I do about the hardness. I bought 5lbs of clorox calcium hardener, and it says to add 5lbs for 10k gallons for an increase of 50ppm (so that'd give me a bit over 100ppm at 4600gal, which would bring me to probably right around 200). My concern is if this is the correct thing to do or if I have incomplete information? 1a) will this calcium hardener raise my ta? 2) should i continue lowering my ta, or let it be for a little bit and monitor it, and how often should I monitor (I've read everything from daily to a couple times a month). 3) I evaporate/splash out about 1 - 2 inches a week during hot summer days (I have a solar cover that only comes off when we swim), so I'll be adding fill water somewhat frequently. Given my well water, what would you suggest my target ta be? Should I try to go low to allow more buffer before I'm in the high range, or should I just be ok at the higher end knowing my fill water is high?
I did a terrible job at this last year (but hey, my kids didn't get any water borne illnesses so that's a win right?) And by the end of the season it was pretty dicey, my cya was absolutely through the roof before I realized all the pucks i was using was killing me. I also switched from the crappy strips to Taylor's fas dpd kit. Trying to actually care and keep it safe, clean and proper this year.
Current levels
Cya 45
Ta 120
Ph 7.5
Hardness 70
