This will be our 2nd year in our new home, and my 2nd year (EVER) with a pool. Thanks to TFP, my 1st year was somewhat successful - but I've always been troubled by some facets of our ancient pool.
1 - Pump and Filter
2 - Skimmer
3 - Returns (Red arrows indicate attempted water flow created by eyes on the returns)
This is an OLD pool, installed in the mid-to-late 70's. Manufactured by Clayton & Lambert, it measures 19' 3" x 37' 2". Stainless steel walls, dirt bottom, vinyl liner. Previous owner dug the deep end to 10' 6" when the liner was last replaced. Shallow end is 3'.
Issue #1: My biggest concern is that there is no drain in the pool. What you see in the deep end is the robotic cleaner, which means the *ONLY* outlet for water is through the skimmer. The 2 returns are fairly high on the wall - approximately 2 feet from the top of the pool. I don't see how this pool can circulate properly, and that caused me to run the pump 24/7 last year. I would love to hear from others as to if this setup/layout is sufficient, or if we need to look at re-working/re-plumbing? A bigger pump would move more water, but even with aiming the "eyes" on the returns, I don't see how I can possibly get movement at the bottom of the deep end?
Issue #2: We want to convert to salt water, but with such an antiquated, minimal design, I'm not sure that it would work. Anyone have thoughts?
If this isn't the proper forum, please let me know. Thanks TFP readers!!
PS - The diving board was installed prior to us buying the home, and it drives me crazy being at an angle! LOL
1 - Pump and Filter
2 - Skimmer
