Hey Guys,
I am pretty new around here. I have come to found this place a wealth of knowledge so far! I hope one day I will be able to contribute myself to help others!
Let's start off with - this is my first ever pool. Recently purchased my new home with an 18' above ground vinyl pool. After taking the cover off, vacuuming, and putting the pieces together for the pump, filter, and heater i took some water samples to the local store to see where to start....
I got another test done today at my local pool store. I have had very high copper levels since the beginning (3 weeks or so). And over the last week I added metal free to the pool, and will be washing / cleaning the filter next Tuesday (will be one week since).
Could you guys take a look at the pool store numbers and let me know your thoughts?
I have added Dry Acid and Hardness powder tonight based upon their recommendations. However, I have a feeling you guys might be able to provide additional insights. I have about another 6lbs of the Dry Acid and another 12lbs of the hardness to add. Is this normal to add this amount to the pool? Based on the instructions for levels for both - and the instructions on the back of the containers, it does seem to make sense.
When i was leaving the store - the clerk said 'oh you may want to add some chlorine'. At least that's what i think she said. Did she mean shock? Or partial shock? I have the 1lbs bags that seem to be a weekly treatment depending on use etc?
I am using the store tests along with some tests strips to get a feel for the test strips and their accuracy (and the stores) so that i can slowly start to understand the water chemistry for myself without being reliant on the store tests.
Sorry for all the basic questions. I just want to get an idea of how close I am to where i need to be. I have summarized my questions below:
* Is adding the acid and hardness together OK?
* Is the amount I am adding sensical and in line with expectations based on the water test results?
* How bad is the .6ppm copper result? How much should this come down with the metal free treatment i started on Tuesday?
* How close am I to having a swimmable pool (with the goal to use it next weekend - if feasible)?
* Next steps? Continue with adding the rest of the dry acid and hardness, clean filter on tuesday then shock? Or other recommendations / next steps?
Many thanks for your assistance.
Date | pH | Alkalinity | Total Chlorine | Free Chlorine | Calcium | Copper | Iron | Phosphates | Cyanuric Acid | Instore Test |
05/21/2021 | 7.5 | 134.0 | 2.13 | 1.92 | 47 | 0.6 | 0.1 | 2 | 65.0 |
