- Apr 24, 2022
- 254
- Plaster
- Pentair Intellichlor IC-40
I am finally out of the startup phase. Questions on going forward, what should be my next steps to prepare for salt?
I’m thinking should I put the swg in now or wait until next year since it will be getting cooler weather, thoughts?
My ph has drifted up to 8 but I bring it down to 7.8, 7.7, 7.7-7.6 puts my lsi and csi negative. I had to keep it higher due to low TA. Should I increase my TA to give a buffer and if I add salt, this will put my csi negative. I also need to increase my CYA as well.
I am stuck on what steps I should be doing. I didn’t realize my ph drifted up that high, I was mistaken by the acid demand thinking it was dropping it to the next tier below. I plugged it into pool math and realized that wasn’t the case.a full acid demand is dropping it more than .4
