Hello!
New to TFP! I've read the pool school and have the pool math app.
We are in south Texas and have a small Intex vinyl sided/metal pole frame pool with 3,500 gallons. We have the little Intex pump (that takes the paper filter) and I got an Orca reusable filter that I clean everyday or every other day.
Our pool has been cloudy since a few days after we opened it.
I'm saving up for a test kit so am using strips right now.
Best I can tell with these strips here are my levels:
FC 10
PH 7-8 ish?
TA 40ish
CYA 80ish
I added 9oz of 10% bleach this morning and FC has yet to drop. I was using pucks in a floater but took those out since finding TFP.
I am seeing a little bit of algae when I clean the filter that is getting killed off. We are vacuuming and brushing the pool.
I'm not sure how much bleach I should be adding each day while I'm trying to clear this up? I'll try to do a overnight chlorine loss test tonight and see if I can tell on the test strips.
Do I need to do anything about the PH? And can we swim right now? I'm a little concerned over the FC level but if the CYA is high it's 'bound' right?
Thank you! So glad to have found this forum.
FC 10
PH 7-8 ish?
TA 40ish
CYA 80ish
