Hi, we're taking over our pool maintenance as our pool guy just retired--without much notice. We've lived here only a couple of years and this is our first pool, so we don't know anything. Ordered a test kit, but in the meantime I had our local pool supply store test the water and our CYA is super high(100) (pool guy used 2 tabs/week). I plan to drain 50% of the water next week so I can use liquid bleach from here on out.
FAC= 3; TAC=3; CH= 270; CYA=100; TA=100; PH=7.5
Where should I look or post on this forum to answer this question:
**Should I do anything special (during drain/refill) because of our copper plumbing?**
I bought a 1/4 HP submersible pump and plan to not add any chlorine (will test) until the FAC is 0 as mandated by our local gov to drain safely into the storm drain. The local rules are: water dechlorinated, pH of 7-8, no algae.
The reason I ask about metal is that shortly after we moved in, our pool maintenance guy (holdover from last owner) wanted to drain and refill due to high CYA and a few days after the refill we had dark, dark brown water. He said it was because of metal in the water and we don't want this to happen again. That was 2 years ago. I honestly suspect he retired at this very moment so he wouldn't have to deal with draining our pool again!
Thanks!
Thanks!
