Probably, if not higher. What you just posted would make a sample that was 25% reagent, not 50%. and 25% pool water.
Jennica said:Thanks Allison.![]()
The second part of that paragraph says:
OR, mix a smaller sample to begin with:
a) Measure 4ml R-0013 into the mixing bottle.
b) Measure 4ml pool water into the mixing bottle.
c) Measure 8ml tap water into the mixing bottle.
d) Continue from step 3 above.
Maybe there should be a:
e) Double the result?
I'm in the refilling process now. I can't wait to get this done. I wish the filling part was quicker. I can drain 6 inches in about 30 minutes but the refill takes 4 hours.
Linen edit...this post of mine is wrongaa62579 said:Jennica said:Thanks Allison.![]()
Except for I think it should be more like TRIPLE the result since that has your ratio of pool water to tap water as 1:2 instead of 1:1. (I just don't know if that is enough reagent for a true result or if your reagent needs to be 1:1 to match your water sample mix. This has it as 1 part regent to 3 parts water.
Once you believe you have your cya under 90 ppm then testing using the 1:1 method (1 part pool water to 1 part R-0013) is appropriate and you would read the result directly with no multiplication factor (no step e and no step c).Jennica said:Thanks Allison.![]()
linen said:Without the dilution, the test is 1:1 (1 part pool water to 1 part R-0013) making the percent pool water 50%. When Allison did the process as mentioned above, the ratio is 1:3 (1 part pool water, 3 parts R-0013) making the percent pool water 25%. Since 25% is half of 50%, the multiplication factor of 2 is correct.aa62579 said:Jennica said:Thanks Allison.![]()
duraleigh said:First, welcome to the forum!!
Secondly, the dilution method you used was close but not quite correct. Use 1/4 tap water, 1/4 pool water and 1/2 reagent.
linen said:The method in your posted here is fine for high cya (over 90 ppm) and yes you do step e for this method:Once you believe you have your cya under 90 ppm then testing using the 1:1 method (1 part pool water to 1 part R-0013) is appropriate and you would read the result directly with no multiplication factor (no step e and no step c).Jennica said:Thanks Allison.![]()
Here are the cya extended test kit instructions to help clarify.
Allison, I think you are right on this...I am checking now. The two procedures indeed appear to be different. Thanks.aa62579 said:linen said:The method in your posted here is fine for high cya (over 90 ppm) and yes you do step e for this method:Once you believe you have your cya under 90 ppm then testing using the 1:1 method (1 part pool water to 1 part R-0013) is appropriate and you would read the result directly with no multiplication factor (no step e and no step c).Jennica said:Thanks Allison.![]()
If you will notice, what is listed above (the 4 reagent/4 pool water/8 tap water) does not match the extended test directions you linked to. They are correct and match Taylor.
"If your CYA level is 90 or higher, repeat the test adjusting the procedure as follows:
Fill the mixing bottle to the lower mark with pool water.
Continue filling the mixing bottle to the upper mark with tap water.
Shake briefly to mix.
Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark.
Continue the test normally from step 3, but multiply the final result by two."
linen said:Allison, I think you are right on this...I am checking now. The two procedures indeed appear to be different. Thanks.
@Jennica...where did you get the instructions you posted?
aa62579 said:Thanks. I don't mean to be argumentative, but they are different procedures and I don't understand how they would give you the same result.
Jennica said:Yes, that's where I got it. So, to be clear.....I should do this method?
Rinse and fill the CYA dispensing bottle to the indicated mark with sample water.
Add the same amount of tap water. (For instance, if you filled the dispensing bottle to 7 mL with pool water, add enough tap water to bring the volume up to the 14 mL mark.) Cap and mix thoroughly.
Uncap and pour off half of the sample volume (in our example you’ll be back down to the 7 mL mark).
As specified, add the Cyanuric Acid Reagent to the remaining sample water in the dispensing bottle. Cap and mix gently for 30 seconds. The sample will turn cloudy.
Slowly transfer the cloudy solution to the graduated vial provided. View from the top while filling.
Stop when the black dot on the bottom of the vial disappears from sight.
Check the liquid level with the closest measurement mark on the graduated vial.
Multiply this reading by 2 for the true concentration. If the maximum value on the scale provided was 100 ppm, in this way you can read up to 200 ppm CYA.
