- Jun 5, 2024
- 102
- Plaster
- CircuPool RJ-45 Plus
I found a WiFi enabled outdoor timer with two independent circuits, and it runs on 240vac so I don't have to have a neutral in the box anymore. I got the Suraielec WiFi Pool Timer and installed it today replacing the old big wheel Intermatic switch. I wired it so the relay feeding the SWG isn't powered unless the pump is also powered. I can turn the SWG off while keeping the pump running, manually, remotely, and by schedule. I've set the SWG to turn on 3 minutes after the pump starts because occassionally it loses prime and needs a few seconds to get happy. Why test fate with only the flow switch. Anyway, I will update as time passes to report on reliability, but I really like the scheduling.
