- Jun 16, 2022
- 5
- Intex Krystal Clear
Hi! Newbie here! Late last summer my hubby installed a beautiful deck over/around our 9 ft diameter, 2 ft deep poly stock tank pool. (I'll post pics soon.)
We have an Intex sand filter/SWG combo (probably overkill, I know). Anyway, for the approximate month we had it last summer, I don't remember having all the chemical balancing issues, but before we opened it this year, we cut down a ton of trees that shaded the area, so the pool gets a ton of sun now.
I've read through the basics on this site, and realize one big issue is my testing...I've been using strips for most. I have a kit, too, but only tests chlorine, bromine, and Ph. I am researching a new test kit.
Anyway, total hardness on test strip says 250, chlorine is always too low except in the evening after I have run the chlorinator for a little while (I usually only do 1 hr cycles...is this good?)
The Ph is registering between 7.8 and 8.4 on both strips and test kit everyday, even though Ive used quite a bit of Ph down. CYA (stabilzer on strip) says 50. I used some Clorox Scale, Metal & Stain Control (what the heck is the main ingredient in this?) when we first opened it, and it's not cloudy anymore, but did I mess up something with this product? I've also shocked with the clorox xtra blue 6 in 1. I know these aren't recommended products here, just frustrated with the chemistry, how long to run the pump and chlorinator everyday, and how to keep ot all balanced!
