We just had a new gunite pool built and waited 72 hours after plastering to add the chlorine as instructed by the pool builder. About 15-30 minutes after adding the chlorine, the water went from clear to a Greenish-Brown color. I had it tested and there was no iron, copper or phosphates in the water. The alkalinity was really high and PH was at 7.6. I’ve been working on lowering the alkalinity with muriatic acid. I’m also trying to get the chlorine level up to an acceptable range, but the higher it gets, the darker the greenish-Brown the water gets. Any ideas on what might be causing it?
