New pool
Every pool and situation varies. Take a look at our Pool School - Determine Pump Run Time page. In short, run enough to mix chemicals, keep the surface skimmed, and vacuum. Other than that it's totally up to you based on how the water looks. Time of day really doesn't matter, although some believe at low light/sun times you get better cooling from the misting. VSPs sometimes need to ramp-up once or twice a day to purge bubbles that may get trapped in the pump basket.
+1 to the answer you already have from Pat above.
You could start at around 12 hours on low speed and see how it goes for a week. If it's real sparkly, reduce by an hour for the next week. If still sparkly, reduce again, repeat, until you notice that it's not as sparkly as you'd like, then go back up by an hour.
As far as time of day, I like my pump to run when I want the pool skimmed and looking its best. So it's just a personal decision.
When you get a chance, check the HP on your pump and add it to your signature. Helps everyone here know how your pool is set up. Thanks :)
