Hi all
See images
My pool and spa is about 4 years old. We appear to have a problem with the material of the spillover. It's falling apart. I'm not exactly sure what material it is but is quite smooth. It was installed 2020 and within a short period of months it started to fall apart and need replacing. It was replaced under warranty , but now it's breaking up again. It can get quite dangerously...sharp on the edge, plus I have had to re-grout certain areas to minimize water lose.
I guess my question is what material should be used for this? Also should I just be getting a pool company to do this vs DIY (I do enjoy doing my own things where possible).
Other info
My pool is only small (maybe 3500 gallons) and I run the pump full speed for 4 hours per day and on lower speed for 8 hours. Spillover during full speed is a good flow off the edge and into the water. The image was taken when on full speed.
On low speed it is trickling down tile and I am sure is the reason that the grout is eroding on blue tiles underneath. Maybe after it's replaced, I should just be running it for less hours but more on a high speed to minimize this erosion??
See images
Other info
