Hi all, this is my first post so pool experts, please dont chew me out...?
We had our in-ground pool constructed last year with a UV and SWG systems along with 14 water features (6 fire/water bowls, 3 separated water descent (12 total ft), 4 deck jets, and a spillway).
Is the constant high PH due to all the aeration from the water features? Also, the UV (Solaxx/Renaissance) suck in air and that might also be the cause?
I was told the UV helps kill little bacteria and water is safer for kids (myth or true?).
The UV won't affect much on the SWG since it's connected after the heater, which is after the filter, before the SWG so the generated chlorine would re-enter the pool.
My main concern is the high PH level. What is the best way to maintain an appropriate level of PH without lowering the TA (for my pool)? I tried muriatic acid to lower the PH, which works, but noticed it drop my TA way low so had to add TA increaser (sodium bicarbonate) to bring up the TA level, but now the PH is high again. Please advise. Thank you.
