- Apr 2, 2022
- 802
- Plaster
- Pentair Intellichlor IC-40
Hi all,
(edit - if this is in the wrong thread let me know and I will move it)
After a long time coming, we finished and filled the pool finally! I will try and post pictures sometime of the finished build on the other thread.
The pool was filled with untreated city water, and now is connected via the autofill to our softened house water. After 10 days of doing their startup, the pool builder handed us over the pool yesterday. They will come back on March 20th to salt the pool and turn on the SWGC, so all of the below is pending that occuring. They have had me running the pump 9 hours a day at 2750 rpm (roughly 4.5x turnover if the GPM is right) and brushing twice a day. I turned the pump down today to 1500 rpm as a test.
I went through the first chemistry test with the pool technician before they left and this is the first results using a Taylor K2005 kit.
My questions if anyone would be kind to answer:
1) Do I start adjusting now or wait for the SWGC and salt install?
2) If I start adjusting, do i wait for CL and PH to come down into range per the technician or is he incorrect? I didnt think a shock would affect Ph...
3) If I understand the chemistry, CL and PH are high, the TA and CYA are ok, and CH is low. Should I be looking at the here and now given we are not using the pool yet due to temps and wait for the SWGC chemistry, or target the future chemistry levels to be appropriate for a SWGC?
4) How do you test for CL and PH levels when they are above the range of the test panel?
4) Any other thoughts on the chemistry?
I have the TF-100 kit on the way along with their Ph meter and Taylor borate strips, I hope that helps with being able to read the levels that are above the scale.
thanks much and war m regards,
I look forward to being active in this community!
regards
Brian
- Pool temp: 69 F
- Chlorine: 10+ (off the scale)
- PH: 8+ (off the scale)
- TA: 70
- CYA: 60-70
- CH: 180
- Borate: TBD test kit
regards
Brian
