- Jul 21, 2013
- 65,062
- Plaster
- Pentair Intellichlor IC-60
I was advised not to go that high during curing process.
150 and not 250-300
What do you think the correct number is?
So make it 150. It is better than 100.150 and not 250-300
Ty. It is almost 150 today. Need to buy more chems to slightly raise it to 150+. Pebble tech recommends 150 to 200 max during the30 day cure period and then the higher recommendation of 200 to 250 after 30 days.So make it 150. It is better than 100.
Although I would go to the high range they recommend of 250.
Low calcium causes the water to suck it out of the plaster which weakens the plaster.
While you are contemplating what to do your low calcium water is weakening the plaster. It is not sitting there waiting for you to do something.
Ty. I do see that. I guess my PB was advising me of middle ranges and not full range. Either way I need to buy a few more chemicals from tractor supply or a box store warehouse. Being a new pool owner, I’m still looking for sources for my chemicals. I live about 20 miles from town and trying to find something closer and away from the pool stores.
That's a great deal. I'm seeing $1700 to $2000 for just the cell and controller right now. $500 for installation is fair most places, and some charge well beyond that, so i'd jump on Leslie's offer.My big question is, though I do not buy products from Leslie to treat my pool, they are running a sale with free installation of their equipment. I can purchase a Pentair IC 40 chlorinator and the required box to supply the power for less than $2000 including installation
Yes. It's an AC to DC transformer / converter. The controller lasts several cells, so the first few replacements only need the cell.Do I still need the power supply box that they say I need?
They IO Relay board can, and should, be added to the Intelliflo3 pump.Do you have the Intelliflo3 with Relay board? If so, I believe you want to wire the SWCG power center through that so power to it is controlled to when the pump is running.
Thank you I will check on that. I do know that I have a 16 amp relay for the pool lights that show on the app.. I will get the model number off the pump and investigate. Sadly, my PB has been pretty much absent since the pool was finished. His excuse is 30% of the pools he’s put in this year as customers complaining, and I am one of them. I’m not sure if he has lowered his standard for contractors or if he has just been over stretched or too busy to pay attention to detail.They IO Relay board can, and should, be added to the Intelliflo3 pump.
🔥 356365Z Pentair IntelliFlo3 VSF Speed Pool Pump I/O IO Relay Control Board
Get 356365Z Pentair IntelliFlo3 VSF Speed Pool Pump I/O IO Relay Control Board from Best Pool Shop online or locallybestpoolshop.com
I can connect to two pieces of pool equipment. So far just a pool lighting.They IO Relay board can, and should, be added to the Intelliflo3 pump.
Yup, you have the IO Board and can use the other relay for the IntelliChlor.I can connect to two pieces of pool equipment. So far just a pool lighting.
Make sure the installer wires the Intellichlor Power Center
Flip a coin. They both have their pros and cons.What’s your opinion on staying pent air or using another option like, CircuPool SWCG? Again, i’m pretty much plain Jane with no automation. I have PA app and one of two relays available for use.
