Welcome to the forum!
Only way to reduce the salinity of your pool water is to remove some of it and replace it with fresh water. Tablets actually add salt.
Why do you think you need to reduce your salinity?
I suggest you read ABC's of Pool Water Chemistry and consider reviewing the entire Pool School eBook.
Well I was told that was too high but it it not holding the chlorine I bought some CYA today, should
I put that in. Pool store showed my CYA was very low
We can't say without knowing a full set of test results, but NOT from a pool store. Only from your own reliable kit that contains the FAS-DPD test for chlorine .
You can get a kit like we endorse at www.tftestkits.net or Amazon. But Amazon costs a bit more. Since you're in NC I would just go to tftestkits as they ship out of NC.
