So I have had a small Intex pool for a month now, water has been crystal clear. Been using the following weekly additions: 10X 1" Bioguard SilkGuard Complete (Trichlor) tablets, 1/3 lb Smart Shock (Dichlor) and 3/4 fl oz Backup 2 Algecide.
Being somewhat OCD I found the pool math app to track everything. The past 2 weeks I've had my pH drift upward to 7.8 and have lowered with lo 'n slo (Sodium Bisulfate). Took my water to the pool store yesterday to get tested and got the following numbers with pool store recommended numbers in parenthesis:
pH: 7.7 (7.4-7.6)
TA: 97 (125-150)
CH: 161 (172-225)
FC: 1.9 (1-4)
TC: 2.1
CYA: 72 (30-200)
Phosphate: 1026 (0-500)
I've been logging everything in the Pool Math App and its basically telling me to do the opposite of what the store says for TA. Store says to raise it with 2.5 lbs of balance pak 100 (baking soda) and to add 0.5lb lo 'n slo (Sodium Bisulfate) to lower my pH. But pool math is saying my TA is too high and that it should be 50-90, add ALOT more chlorine(6-8 ppm) for my CYA level and that pH is fine. Suggestions? I'm tempted to just leave TA alone. Why is there such a big difference between the TFP suggested numbers and the Bioguard suggested numbers?
pH: 7.7 (7.4-7.6)
TA: 97 (125-150)
CH: 161 (172-225)
FC: 1.9 (1-4)
TC: 2.1
CYA: 72 (30-200)
