Two weeks ago we purchased a house with a pool (21000 gal), not having been responsible for one before, we are a little overwhelmed. The person who we bought the house from used a pool guy from Leslie's to come and take care of the chemicals and everything else with the pool. Based on reading posts on this forum, and the condition the pool was in when we moved in, Leslie's seems like a very bad company to use. Even though the pool guy was on site the day before we closed, the day we arrived the pool was green and had no chlorine levels in it and the filter was running at high pressure suggesting it hasnt been cleaned in a while, I shocked the pool and the green went away pretty quickly and backflushed the filter which restored the pressure to a normal level and gave the pump outlet nozzles more flow.
Currently the water looks crystal clear but I am just trying to get a handle on things so that I am not spending 2+ hours a day trying to figure out what is going on with the chemicals. The previous owner had 3 different kinds of test strips and I purchased a test kit to check levels (Blue Devil B7550). (The most recent thing that I did was add baking soda to increase the alkalinity, which I probably over shot)
The results of those 4 tests averaged as follows:
- CC and FC = 0 or close to 0
- pH = 7.7-7.8
- Alkalinity = 180 - 200 ppm
- Cya = "High" on test strips, 90 on black dot test
I also had the water tested at Leslies which gave a nonsense result where it recommended hundreds of dollars in chemicals and another local pool store that just said my cya was high (119) and I just need to drain some water out of the pool.
The way that pool is configured, there is only a skimmer close to the water level as the inlet to the pump, so I can only drain about 1400 gallons out of the pool at a time. The filter unit by the pump is hard piped into the main drain to my house, so the water would drain out that way. I have two submersible pumps, but no where to direct the water (no nearby storm drain). I was planning on just draining out the 1400 gallons this weekend and refilling and re-testing again and just repeating until a better cya level is reached.
I am fairly overwhelmed here so any advice would be appreciated.
- pH = 7.7-7.8
