- Mar 14, 2024
- 76
- CircuPool RJ-60
Hi everyone. I put what I could in my bio. Just bought this house and moving in soon. During my final inspection, I snapped some pictures and I have some questions on if this set-up needs any attention, or if its good to go. I have never owned a pool so I don't know what I am looking at here. I will convert the pool to a R60 SWG right out of the gate, so I know there needs to be some interlocks on the SWG so it does not generate when the pump is off.
Question 1 - There is a push button switch that turns the pool pump on-off. The pool is also on a timer. Why would I need a start-stop switch - is that for long-term pump closure....or in case there is a need to do wiring work (which should be isolated at the breaker). Also, are these INTERMATIC manual timers in need of an upgrade or are they still good - looks cheap compred to all of the other pools we looked at house hunting?
The one on the left is the pool, the right is the waterfall pump. Push the button and the pool pump turns on.
This is the INTERMATIC switch.
This is the sand filter. The label is worn off so I have no idea what model # or size it is or if its in need of service. Only thing I know is its Max 125 GPH. I was just planning on back flushing it and leaving it be.
This is the pool pump - Centruy 1081 1.5HP
Waterfall pump - Pentair Dynamo 1.0HP
Not sure what this riser is coming from the ground at the waterfall pump. Expansion?
Question 1 - What is this little pipe going to?
Question 2 - I assume this is some sort of sa manifold for cleaning - automatic jets?
Question 3 - I think this is the right plaxce to put the SWG. right?
I am sure I will figure it out with or without help - but hopeful You all can lemme know if anything in this system is worthy of upgrading. As far as I know, everything works as is.
