- May 3, 2014
- 62,730
- Fiberglass
- Pentair Intellichlor IC-40
I’ve got one that hooks up to the hose and I manually push it but not a robotDo you have a vacuum? It will get more crud than scooping. Which will clog the filter and you’ll have to backwash (anytime the PSI raises 25%). but still worth it. Especially when you’re doing it blind.
The skimmer basket would catch it. It could very well get jammed up in the hose though. Worth the risk there to me.The next problem could be a rock that managed to get by the vac head and get jammed in the plumbing on the way to the filter
This is exactly what I haveor get this this and don't worry about all that
Then it’s what we have to work withThis is exactly what I have
Can you explain what ppm is?You need to remove the large organic debris without damaging the liner.
that can be challenging without visibility.
Hopefully add the 5 ppm of FC per day now will help kick start things.
So if I have a 25,000 gallon pool what would the right liquid chlorine be per day? This is all rocket science to meParts per million.
