Re: New pool owner,, first post, just getting started
--Sorry, was on the wrong page.--
Draining now but looking at your post at just the right time. When the water got below the skimmers, drain rate slowed down a lot, but then I saw your post and shut off the skimmer valves. Thanks! I may get down to 1.5 feet in the shallow end (of a 3 foot pool) both because I am nervous to go to low for my vinyl IG pool but also because I didn't look into whether I could get a break on sewer rates for a pool fill (it's Sunday, but I did take a picture of my water meter before starting the fill). And thanks for the encouragement. It feels a bit overwhelming right now...Unless I'm confused, you're draining about 50% of your water today to get to a CYA of 60, correct?
Since the pools new to you, I just want you to know that whenever draining a vinyl pool not to drain lower than a foot in the SHALLOW end. Be sure to close the skimmer valve, but not the drain valve, and set your multiport to waste.
Once you've refilled, ran the filter, and retested everything, then adjust your ph to 7.2, check the slam level you need in the [FC/CYA][/FC/CYA] - use Pool Math to calculate how much cal hypo to add to get to the target Slam FC and you're on your way
If you need refreshing on the Slam process, read up here: SLAM Process. I think you'll be in for a short slam and swimming in no time![]()
I found the plate! One question on the plate: it seems to make the attachment possibly higher than the water level in the skimmer. Is this a problem to create or maintain a primed vacuum line?Welcome to TFP by the way!!
+1 re: AimeeH's comment to keep the skimmer basket in your skimmer when vacuuming. You want to keep the big stuff out of your plumbing. There should be a plate that goes on above the basket with a hole sized for a snug fit on your vacuum hose.
You can probably find a owner's manual / installation manual for your skimmers. In my case, the plate is removed when not vacuuming to avoid the vortex, reduce friction loss, and eliminate the suction risk of pulling water only through the small opening used for vacuuming. Skimmers can be set up better than mine is, so a manual for yours would be worthwhile reading. Or you can post pics here and the experts will fill you in.
Thursday is optimistic, but the shortest possible is if you hit it hard and MAINTAIN Shock FC.
Yeah, I will try shutting off the drain and/or other skimmer. The problem with my plate, though, is that it doesn't fit into the skimmer, even without the vacuum hose attached. My only option is to put it on the skimmer basket and try to quickly attach the hose without letting in too much air, I think?Can you shut off one skimmer?
I have a shut off valve for both skimmers and a main drain......3 valves. When vacuuming as I described using the plate, I fill my hose with water at a return, put the plate on the hose under water and walk it under water to the skimmer with the plate attached to hose and place over skimmer. Suction from there takes care keeping it in place.
I usually only shut off my main drain and have adequate suction without shutting off other skimmer.
If I were to attach the hose to the plate and walk it over under water to the skimmer, the plate wouldn't fit through the skimmer opening at the side. It only fits in from the top over the skimmer basket.Describe "doesn't fit the skimmer"?
If where the hose attaches puts it above the water line, it could suck air......bad. Attach it to the hose then place quickly over skimmer.
So you actually quickly pull out the hose (attached to plate) OUT off the water to place the plate over the top of the basket? Hose is then attached to the skimmer through the deck opening, not the water intake? The Youtube video's I watched all showed the hose going into the intake.Same setup as mine pretty much. I just attach the skimmer plate to the hose while keeping it under water then quickly get that plate in the hole in you picture that is from ABOVE the skimmer.
Don't get too frustrated. I was just as much as a newbie as you when we had our pool put in 2011.
To avoid that skimmer plate sucking air, I attach it to the hose after Filling hose with water from return. It is simply more difficult to fill hose with water if skimmer plate is already attached. Then when I walk it to the skimmer I quickly pull it out of the water and attach from top of skimmer......the opening pictured in your photo. It is a tight fit, and suction keeps it there. I don't get any noticeable air in my system this way.
Yes, to lower CYA. Over 120. And thanks for the picture. Worth a thousand words!To lower CYA.......the reason your draining? You can do several partial drains and refill and circulate water, test then drain some more, refill. Test water and drain more if necessary. It can be done in steps like that.
