- Jan 4, 2016
- 5,293
- Plaster
Re: New pool owner,, first post, just getting started
At the right level, CYA is your friend (stabilizes the chlorine, acts like pH buffer does for pH) and at the wrong level, it's your enemy. The experts have said to get it down to 50. If you were at 120, and you drained 5K from 30K, you're still at around 100.
I feel your pain, but at 100, your SLAM level is 39 ppm FC. That's 80 drops of reagent for each test, around 10 gallons of 12.5% chlorinating liquid, or 14 gallons of 8.5% bleach just for the initial charge of chlorine.
At 50, your SLAM level is 20 ppm FC (40 drops of reagent, 5 gal 12.5% or 7 gal 8.5%)
If you can see algae, you definitely need to SLAM. You'll be doing the test 10 or 12 times at least. And adding bleach like crazy. The SLAM is totally the right thing to do to make your pool easy to take care of afterwards. As long as your CYA stays up at 100, even after all the algae is dead, you'll be targeting around 10 ppm FC instead of 5 to keep it safe. The drain and refill is just the most practical thing to do, and makes for less work overall.
It's possible to do the SLAM at 100, but just not practical. And caring for your pool after will continue to take more effort as well.
I'm no expert, but if it was my pool, with 0 FC, after I was done for the day with the drain/refill stuff, I'd dump 2 or 3 gallons of bleach in, to stop the SLAM from being more work. That algae is multiplying, and 10 ppm FC (at 100 CYA) would at least stop the growth. I think it's a good bet that your pool isn't green already because the water is still cold.
Sorry for the long post, but cold makes me think of two other things that might help. If your water is below 70 degrees, allow the sample to warm up to room temperature before adding the CYA reagent. The other is a cold beer or two while waiting for it to warm up!!
