- Jun 22, 2017
- 861
- Vinyl
- CircuPool RJ-45
I know it's been a long year already, but don't think we've hit the "200th week" yet xD. Any jug over 17 200 is definitely good. My last stock up was from 17 184. Another thing, all these jugs of bleach, you are keeping them inside your house, or at least somewhere that never exceeds 80°F, right? Once chlorine hits 80°F, it starts degrading even without sunlight. On a side note, make sure you don't store chlorine and muratic acid anywhere near each other, if the concentrated forms of them combine, even the fumes, they will create some pretty nasty, and very dangerous gases that won't end pretty for you.
If you're running low on the reagents, and with all the testing you probably are now or will be by the end of this, order yourself the XL Option from TFTestKit's site. It's got the powder and larger bottle of reagent to test your FC, and comes at a discounted price compared to buying separately. I'll have to look up exactly how, but I also remember reading about a way to test your FC that's accurate to 1ppm instead of .5ppm and uses half as much reagent. With your pool not holding chlorine, knowing accurate to .5ppm isn't gonna help you anyway.
Just found out how, use 5ml I stead of 10ml, and each drop will count as 1ppm instead of .5ppm. So if you add 5 drops to get it clear, it's 5ppm. When adding the powder, if you still see some undissolved powder in your vial, you can use a little less powder next time too. Just make sure you still see a grain or 2 of it undissolved, or you might not have added enough.
