JoeSelf
I don't see a light, but have you pulled ladder and checked inside?
definitely possible. easy to check.....I do have a light and latter. Possible nasty monster of bacteria/algea living in them?
What brand bleach are you using? Does it show 6% sodium hypochlorite on the label?
It would be unusual to use that much chlorine in a clear pool for a SLAM.
Take care.
Not in the light, but behind it, in the cavity. There should be a screw (maybe two) that holds the fixture in. There is rarely good circulation in the crevice. Ditto for the ladder, particularly if the cross beams are fiberglass. there are nooks and crannies on the underside of the steps.I do have a light and latter. Possible nasty monster of bacteria/algea living in them?
Mknauss makes an interesting point. Most extra strength (8.25% or more) bleach detail it on the label. I've seen only a few 6% labels do the same. If it is not indicated, you may be dealing with as low as 2% concentration.
Definitely sounds like an ammonia issue to me, but I am relatively new at this and my only experience with ammonia is reading about it here on TFP.
Finally, I agree with sccm. Try sourcing higher concentrated bleach. Your FC is way too low and your CC is way too high and it's tougher and more expensive to achieve the necessary levels of FC with your size pool at that concentration (as you have experienced).
Ha! you beat me to it. i was just reviewing previous posts to see if the filter had been addressed yet. also the obvious point of emptying the skimmer and pump baskets..these seem so obvious but i recall seeing a recent post about someone having one full of leaves..........
When was the last time you opened up your sand filter and deep cleaned it? If you are experiencing high FC demand and persistent CC levels, then you need to hunt down every possible location where stagnant water and organics can hide and make sure they are clean.
Let us know what the inside of the filter looks like and we can go form there.
It is highly unlikely to be ammonia as you have proven that your pool can achieve a high level of FC but just can't seem to hold it. If ammonia were present in the water, you'd never get it up to 16ppm FC.
A couple of things - stick with straight bleach or liquid chlorine, highest strength you can find (10% is usually a good trade off between concentration and shelf life). Cheap bleach (6%) is often very old (check the date codes) and will be nothing more than salt water with a hint of bleach flavoring.
As for the Baquacil AlgaeDefense, well, other than wasting your money, that product did little or nothing for your pool. It did add sulfates to your pool which is not a good thing if you had a plaster pool or salt-water chlorine generator. But, in your case, it shouldn't cause too many problems. The zinc will eventually come out of solution as a white precipitate (zinc oxide) that will mostly be captured by your filter; at the concentrations you added, you probably won't even notice it.
Thank you so much for the feedback and knowledge. I just replaced everything including Sand filter and switched to "ruby" sand. Was told glass based and more efficient. New pump and SWCG as well. 2 weeks ago. Thanks.
Strainer cleaned daily.
Think of anywhere organics can hide. Not long ago someone found an algae reservoir in their automatic fresh water fill line. Every time the auto fill ran it added more than water. Stay with it.
In reading about Ruby sand, it is porous. That is interesting. It is fired Montmorillonite(clay).
Not sure what curveball that could include.
Hmmm...well, unless the filter was cracked or damaged in some way, the new filter and sand was probably a waste. Honestly speaking, TFP never recommends changing sand; unlike pool stores, we recognized that sand is tens of millions of years old and can not, in any way, shape, or form, "go bad". But, what's done is done.
If you want to definitely rule out ammonia, you can go to any pet store and purchase an ammonia test kit for about $8. It would be highly unlikely that you do have ammonia as the reaction between ammonia and chlorine is immediate and complete (forms chloramine) but $8 would bring some peace of mind if you're willing to spend it.
Other than that, the only thing you can do is to get the freshest bleach possible and SLAM the pool. Maintaining the shock level is critical and so that usually requires someone to sit pool side and babysit it for a day or so by doing testing every 2 hours or so and dosing as needed. It's frustrating and annoying to have to waste that kind of time, but you should see the CC levels drop faster that way as well as FC levels begin to hold. With the constant swings in FC up and down, whatever it is that is causing the CCs to stay elevated gets a rest when the chlorine is low. FC's down below 2ppm with your water and sunshine is a recipe for algae and bacteria propagation (even if you can't see it).
It was lightmaster that said use higher concentration of chlorine, just saying![]()
